Aircon compressor not engaging
Old Nov 6, 2005 | 01:57 PM
bluedund's Avatar
bluedund
2003 5.0l Club Wagon, air conditioner clutch not engaging. Owner manual not much help, shows fuse for 4.2l but not for 5.0. (I think 5.0...350 cu V8).
Any suggestions?
Old Nov 6, 2005 | 02:03 PM
ford390gashog's Avatar
ford390gashog
is the engine a v-6 or v-8? because ford does not build a 5.0 or 350. but it could be a blown fuse or bad switch.
Old Nov 6, 2005 | 02:16 PM
bluedund's Avatar
bluedund
It is a V8...and of course, I know it is a 351...I fat fingered that one. I can't locate the location of a fuse for the air con clutch...the manual says that there is only one for the 4.2 and I looked, sure enough, there is no fuse there. The system was working fine a couple of weeks ago, it got cool and didn't need air con, now hot again...no clutch engaging. Sigh...I gues I will need to get it into a shop unless someone knows of a "hidden" fuse.
Old Nov 6, 2005 | 04:26 PM
ColonyPark's Avatar
ColonyPark
They haven't made the 351 in a lotta years. You either have a 4.2, a 4.6, or a 5.4.
The usual cause of the clutch not engaging is low refrigerant. You can short the low pressure switch leads if you unplug it from the accumulator. If it engages, you either have a bad low pressure switch or low refrigerant.
Old Nov 8, 2005 | 04:48 PM
Dannym's Avatar
Dannym
On my '87 I had the wire harness connector that plugs into the clutch go bad. ~$12 to get a new plug.
Old Nov 8, 2005 | 05:48 PM
ColonyPark's Avatar
ColonyPark
Any progress? Interestingly, I had to fix my dad's old Crown Vic yesterday. It had the same problem you describe, no AC clutch engagement. I pulled the connector off the accumulator, shorted it, and the compressor came on. So after adding some refrigerant, it's working great. I really think you'll find that's what's wrong with your van.
Old Nov 9, 2005 | 02:18 PM
bluedund's Avatar
bluedund
Haven't had much time to fool with it. It is my wife's van and now she tells me that the aircon has not been working as well as it normally has been...so I now suspect a shortage of freon. I just hope I don't have a leak...that will be expensive to fix. Freon I can add, leak I punt.
Old Nov 9, 2005 | 02:49 PM
ColonyPark's Avatar
ColonyPark
If it's a 2003, it's R-134a. It's not expensive, they sell it over the counter, and you can put it in yourself. If it's a small leak, I'd keep topping it off every year rather than pay a lot of money to someone. If it's leaking the refrigrant off pretty quickly, then you need to get it fixed before it's empty and draws in contaminants and moisture.
