Bronco II Ford Bronco II
sweet
Old Nov 5, 2005 | 06:35 PM
psycocrazy's Avatar
psycocrazy
sweet
ok yall i get to be part of this forum now!!! i just got an 85 b2. 2.8 v6 auto, 4x4. woo hoo. i got it for like 600 bucks. ill see if i can get some new pics of it up in the near future.
any thing i need to know bout these? any tips?
thankx
later
louis
Old Nov 5, 2005 | 08:00 PM
frankenbroncoII's Avatar
frankenbroncoII
one of the most common problems the BII has is the rear springs are weak and they tend to sag in the rear.
Old Nov 6, 2005 | 06:35 PM
Ken00's Avatar
Ken00
Welcome to the BII forum Louis!!!
Old Nov 15, 2005 | 08:30 PM
psycocrazy's Avatar
psycocrazy
woohoo. i have a pic of the truck, but i need to shrink it down. will try to put it up soon
Old Nov 15, 2005 | 08:35 PM
97Centurion's Avatar
97Centurion
Rub my Belly
Congrats on your purchase! Don't get them hot. The heads are prone to crack easy.
Old Nov 15, 2005 | 08:39 PM
psycocrazy's Avatar
psycocrazy
pics are up on my gallery
Old Nov 15, 2005 | 08:50 PM
97Centurion
Rub my Belly
Looks to be in good shape!
Old Nov 15, 2005 | 09:04 PM
psycocrazy's Avatar
psycocrazy
and the right price too. i got it dirt cheap
Old Nov 16, 2005 | 08:05 AM
dnachristen's Avatar
dnachristen
On the 85, aren't the heads cast iron?
The 85 has a few problems.... mainly the computerized Motrocraft 2150A carb. Get some parts together, and Duraspark that baby.
If you can't afford to Duraspark it, get a code reader. About 35 bucks at any major parts house. Will save you tons of money in the long run. Since it is that old, and if the sensors have not been replaced, you may need to do so. Everyone here can tell you the pains of diagnosing a poorly running engine.
The 2.8L is a good engine. Way underpowered for the size of vehicle, but a great motor none-the-less. Mine does 0-60 in about 3 days...LOL
Avg gas milage, for a clean running 2.8, is around 15-20mpg, if you keep your foot out of it. If your tranny has overdrive, use it, you should gain a few MPG on the highway.
The Torque Converter should lock up at around 50MPH. This is the best place to run... The tranny stays much cooler. You will know when the TC locks up when the RPM drops without a gear change.
The hardest spark plug to get to is the passengers rear... I hate that one. If you have A/C, the easiest way to get to it is through the wheel well with a U-Joint type adapter.
If you have power windows, the lower support in the door is prone to break. If you close your door, and hear ratteling, that's prob what it is.
Check for leaks on your A4LD, the front and rear seals go out rather easily. Hot weather can cause them to spew fluid. A larger transmission cooler, or even two really helps in hot weather.
Since you live in Texas, I would def have the thermostat replaced, and the cooling system flushed.
The Bronco II has GREAT ACOUSTICS!! A stereo tuned to perfection will sound great! Tip... Mids and tweeters pointed at the rear side glass, at a 45deg angle is frickin awsome! Spreads the sound throughout the cab.
Hope this helps.
Congrats on your new ride!
Old Nov 16, 2005 | 04:27 PM
97Centurion
Rub my Belly
My bad. I wasn't paying attention to the year.
