Hi, I'm a new member and hopefully have found a place where I can get some help! Have a '00 Ford F550 with 7.3. Truck will not start. Changed the CPS and it still won't start. Edge says code P0232 Fuel Pump Secondary Circuit High. Please help!
can be caused by "relay failure", "short circuit", or "pump failure"
Changed fuses in fuse box, decided to put on the battery charger, and found I had a loose battery cable. Tightened it and put on charger for 1 hour, and it started right up. Seems to be running fine now, thanks for your help.
