3.0 differences
3.0 differences
Have two 3.0 engines. One with internally balanced crankshaft (large counter weight in center) and one with externally balanced crankshaft (thicker counter weights at the ends). Both use different balancers. Question is: are they both usable in the any 3.0 block? All other parts look identical (rods, pistons and bearings).
3.0 differences
Sorry, didn't make myself clear. Both blocks and heads are the same. Both are vulcans. Don't have DOHC on either. Both cranks and balancers are different. Both cranks will fit in either block. Difference is the 94 eng has a big center mounted counter weight and smaller balancer and the other has no center counter weight and a larger balancer. Not sure of the year.
farm_boy_22
1983 - 2012 Ranger & B-Series
09-23-2010 11:44 PM
lilwrkmstr
09-15-2008 06:54 PM
