fuel delivery problem
Old Nov 4, 2005 | 07:40 PM
bobert64's Avatar
bobert64
I put the fuel pressure gauge one the schader valve. when its cold it registers about 50 lbs. at high Idle. BUT, when it gets warm and I go to High Idle, the pressure drops to zero and then to high vacuum! the engine dies and after a period of time the vacuum pops, and jumps to about 6 lbs. of pressure. I've replaced the fuel pump, removed filter housing and cleaned all the screens and housing. Has anyone seen this before. Also, it has two tanks and it happens with either tank.
Thanks
Bobert64
Old Nov 5, 2005 | 02:27 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Strange. Did you clean out the regulator while it was all apart?
