Manual to Auto Trans conversion
Old Nov 4, 2005 | 02:59 PM
79brncnwht's Avatar
79brncnwht
Checking this out for a friend. Is it possible to change a 62' F100 ( engine?) from a manual trans with 3 on the treee shifter over to a automatic?
I know any thing is possible with enough work. Was there a automatic trans available to match up to a bell housing? I do not know what kind of engine and tranny combos were avaible then.
Old Nov 4, 2005 | 03:28 PM
garbz2's Avatar
garbz2
Truck ford o matics are real hard to find for the Y Block. And just about impossible to find for the 223 six.
Is it the factory engine? or something transplanted in later?
Garbz
Old Nov 5, 2005 | 05:20 PM
magee's Avatar
magee
I'm not any help on the swap, but was contemplating doing the same thing with my 66/240/3 on the tree. Kinda stuck between AOD an C4.
Old Nov 5, 2005 | 07:22 PM
Customcab's Avatar
Customcab
Probably no help here either; but I had a 300 with a C-4 mount to it; the only difference pass bell housing issue that I'm aware of is your starter will also have to be change from a manual to a automatic type starter.
just to throw more thought into the matter.
Mitch
Old Nov 7, 2005 | 12:26 PM
79brncnwht's Avatar
79brncnwht
Thanks guys, I appriciate the help with limited info.
garbz2-thanks for possible engine type.
I think I will advise him that the 300 w/C4 would be best option.
