"N" code trans, I used to know this...
Old Nov 4, 2005 | 09:45 AM
Mike G's Avatar
Mike G
OK gang, help me out with what tranny it is. 1965 "N" code 4-speed bolted up behind the FE. Granny low first with the reverse to the right and down.
--Mike
Old Nov 4, 2005 | 11:27 AM
barry's Avatar
barry
New Process 435 trans.
Barry
Old Nov 4, 2005 | 02:22 PM
Mike G's Avatar
Mike G
"N" for the New Process, huh...
Thanks Barry --Mike
Old Nov 4, 2005 | 05:58 PM
barry's Avatar
barry
Ford used 2 4 speeds in pickups back then, NP 435 ( reverse over and down ) and the Warner T98 ( reverse over and up).
Barry
Old Nov 4, 2005 | 06:55 PM
mark alderson's Avatar
mark alderson
I have a 65 f250 with 240 6 with 4 speed over and up and 65 f350 with 4 speed over away and back.Will the trannys interchange?And was it common for the 6 cyl.to have the warner and the fe to have the new process?Just curious.
Old Nov 5, 2005 | 08:09 AM
barry's Avatar
barry
Yes, they'ii interchange. I've swapped both out over the years. Last on was a 74 F-100 with a 302 and I replaced the 3 speed with the Warner. As to the 6 using the warner, I can't really say. They're both good units.
Barry
