64 F600 Cab Over Engine Mystery
Stargeezer here:
Just got a 64 cabover F600 to haul water. Original flat bed car hauler. VIN starts out C61Mblahblah. The M must be the engine code. I suspect a 391 - it's a V8 with front distributor and 2bbl. Two questions. Is it likely a 391 and what gasket sets will work for this engine? Also needs at least one hydraulic lifter. Will standard older 390 parts work in the top end? Thanks.
hello; i believe it's a transplant. they didn't use an fe in trucks untill 65. it would have had a 262 6cyl. or a 292 y-block. well my book only goes up to 63 and there's no M code engine. possibly they came out with the 330 in 64, i'll have to check and see if i've got a later motor's manual, wayne.
Lots of Help!!??
OK. Not totally confused but getting there. I like the idea of the 330 with the M engine code. This is a 22,000lb GVWR truck with an empty weight of about 10,000. It has a four speed with a two speed eaton rear end. Same question about parts - am I going to be able to use pretty much 390 FE parts in this engine except for the obvious, pistons, crank, etc. I have a top end gasket set (390) and just looking at the gaskets compared to where they go, looks pretty good. Won't know for sure until its too late of course. Any more good advice?
Thanks to all.
Thanks to all.
wcasey
11-04-2016 07:48 PM
ScallyWaggler
06-05-2015 11:12 AM
ddsprint
06-27-2008 07:44 AM
