Changing Out Oxygen Sensors
Old Nov 4, 2005 | 02:46 AM
SeannyBoy84's Avatar
SeannyBoy84
Question Changing Out Oxygen Sensors
How's it going? I bought a new pair of Motocraft O2 sensors to replace the two closest to the exhaust manifold. Anything special I need to know? Disconnect negative battery post, access through wheel wells, replace, reset computer, and then let idle of several minutes. That's basically it right? I checked and the threads already have some sort of anti-seize on them. Thanks.
Old Nov 6, 2005 | 12:42 PM
bob arrington's Avatar
bob arrington
try not to strip the threads getting them out,bob
Old Nov 7, 2005 | 05:07 AM
dkstuck's Avatar
dkstuck
Dont get the sensor part dirty or try not to touch it. Never use carb cleaner on it! If you do get it dirty, I guess you may wipe it off with gas, but you better check first. Had to replace one that was cleaned with carb cleaner.
rangerbob406
Jan 19, 2013 08:14 PM
Pyancey
Jan 16, 2013 09:08 PM
midsouth
Nov 5, 2012 08:23 AM
jokerswild130
Oct 20, 2008 07:24 AM
RobertJohn
Jan 8, 2005 10:00 AM
