Ok i know i've seen them before but don't know where. it's a gas tank that looks like a seat and goes into the rear bed and people can sit on it. i took the tank out from behind the seat and put a set of speakers in it's place but now i need a tank. thanks for your help.
you can sit on the fuel cell? thats a new one. a company called transfer flow makes gas tanks that double as tool boxes or just one big tank that sits in the bed you might try them
Louis
Crazy,
Does your truck run on hydrogen? If not, you're probably are looking for a fuel tank. They make fuel tanks for POL trucks. That's trucks that fuel other vehicles at construction sites. If you could find one of those, a small one, you'd be good to go.
KingFisher
Fuel cells can also hold gas. Check out http://www.fuelsafe.com/main.html for more info. They even make a fuel cell for Ford trucks.
The main difference between a fuel cell and a fuel tank is a cell has internal foam baffling and/or a rubber bladder to help contain fuel in the case of an accident. If you road race (any type but solo) you must use a fuel cell.
