highway gears
Old Nov 3, 2005 | 05:38 PM
andrewasl's Avatar
andrewasl
highway gears
Hello all,
I have a 71 f100, 360 with stock 2 barrel, manual 4 speed granny sport custom.
I'm looking to change the gear ratio in my truck so that I can get better gas mileage from it. I drive 40 miles round trip to work everyday on the highway and it is geared a bit low right now.
How do I even START something like this? I've looked on the site and got a lot of good information, but where would I go to find the gears I need? Also, what gears should I look for to get the best mileage on the highway? Are they hard to change?
I won't be towing much with this truck and use it for transportation daily.
thanks,
andrew
ps
rebuilding the carb was easier than I thought and it made the truck drive a whole lot better.
Old Nov 3, 2005 | 06:46 PM
banjopicker66's Avatar
banjopicker66
First, we need to know what your current rear end is like. Most likely, you have a 9 inch rear. If your wheels are 5 lug, you have a 9 inch.
This rear is easy to re-gear. You can easily change out the center section, called a punkin, a chunk or a 3rd member. You can also have a shop change out the actual gears inside the chunk, but that takes special tools. Not a job for the novice.
The second piece of information we need to know is what your current rear end gear ratio is, in order to make a recommendation.
Under one of the nuts holding the punkin in place should be a metal tag. Look on the second line for the numbers.
Those numbers will tell your ratio. It probably is 3.50, and would look like this:
3 50
Post back and let us know.
Old Nov 3, 2005 | 08:30 PM
fling's Avatar
fling
You can also get an overdrive unit that bolts to the back of the tranny, It will cost you around $2500 in all, but they are sweet. www.gearvendors.com makes them.
Old Nov 3, 2005 | 08:42 PM
banjopicker66
Very true! I have a Doug Nash unit in my '66 F-100, the predecessor to the GV or US Gear overdrive units.
However, it will be cheaper and easier to replace the punkin, at about $100 or so. Not to mention, the cost of altering the driveshaft.
Old Nov 3, 2005 | 08:46 PM
go_racing84's Avatar
go_racing84
An over drive is very sweet, but it is, as was mentioned, expensive. I got my 4.10s for about $130 on eBay. They were used, but only had a few hours on them. I took my 3rd member to a driveline and differential shop, and they put in new side gears, spiders, bearings, and set the whole thing up for less than $200.
You can set up your own (and really, it's a lot easier on the 9" than others), but by the time you buy some quality equipment to do it with, you could have had someone else set it up for you.
Old Nov 4, 2005 | 04:35 AM
jowilker's Avatar
jowilker
andrew, I run 3.00 rears behind my FE and am happy with it. I have run 2.75s in it, and if I never towed would run them now. With the manual tranny that you have the 2.75 might be a good candidiate for you. IMHO
John
Old Nov 4, 2005 | 04:47 AM
ford390gashog's Avatar
ford390gashog
try www.randysringandpinion.com
Old Nov 4, 2005 | 08:24 AM
TK70Ranger's Avatar
TK70Ranger
I run 3.25's in my truck, can acheive 14-15 mpg if you keep your foot out of it, and that's with the 390.
Old Nov 4, 2005 | 08:47 AM
Mikes67F250's Avatar
Mikes67F250
Gear Ratio
I was thinking about swapping out a 410 for a 373. After tlking to a friend of mine he said to save my money and that the next time I get tires go to a tire that is about a half inch higher and that would make up the difference. Which makes alot of sense. I am running mine with the stock 16.5 rims and 875 tires so I should be pretty close to the 373 ratio. Correct me if I am wrong though. Thanks
Old Nov 5, 2005 | 05:31 AM
jowilker's Avatar
jowilker
Mike, Changing the gears on the Dana 60 is different from plugging in a 9", so your friends advice just might be better. IMHO
John
bztguy
13
Jan 16, 2012 08:35 PM
Localsalt
2004 - 2008 F150
Sep 15, 2009 07:16 AM
fordpower46
25
Jun 13, 2009 02:15 PM
chipper
Mar 23, 2005 06:34 PM
gman17
Feb 28, 2005 07:29 AM
