tuning this 390
Old Nov 3, 2005 | 10:29 AM
bshackelford711's Avatar
bshackelford711
tuning this 390
hello everyone it has been a long time. but now i am back and stronger then ever so while i am feeling good i want to work really hard on my 69 F-100
i built a 390 and put in it.
30 over
941 crane cam
headers
360 pistons
about 10 - 1 comp
carter AFB
now i need to get it tuned up
i need to set the timing and fuel and so on
what is a good place to start
i am thinking the timing. where should i set that? What are some number that anyone else is running?
thanks
-Brandon-
Old Nov 3, 2005 | 10:36 AM
Mike G's Avatar
Mike G
Have you had the motor running already and now it's time to fine tune? Start with gettin gthe timing set up, then go from there. Refresh my memory, where you're located, that will affect your timing of course....
--Mike
Old Nov 3, 2005 | 10:38 AM
rusty70f100's Avatar
rusty70f100
Now is when the fun really begins!
I'd start with, oh, 15 degrees initial, and see if you can set your distributor for 24 degrees mechanical advance. Total should be somewhere around 38 degrees, all in by around 3000rpm. That's where I have my distributor set anyway. That cam does like more initial timing to get it to idle smooth. Use the vacuum advance if you have it.
Timing is one of those things you kind of have to play around with. Every motor is a little different.
Old Nov 11, 2005 | 01:23 PM
bshackelford711
big fun for this weekend just as long as it doesnt get to cold here.
zoomm, zooomm
-Brandon-
Old Nov 11, 2005 | 02:09 PM
rusty70f100
zoom zoom? That thing aint no Mazda!
Old Nov 11, 2005 | 03:38 PM
fordraceboy's Avatar
fordraceboy
we like to hear the chuggita chuggita chuggita.... LOL
Old Nov 14, 2005 | 10:25 AM
bshackelford711
mazda killer zoom zoom !!!CRUNCH!!!
so far so good i have got it running better and now i have got to do the brakes on that thing and i am going to on the street and lay som rubber down.
-Brandon-
Old Nov 14, 2005 | 08:30 PM
davethecow's Avatar
davethecow
Heres a spicy grind for ya.erson e240222 220-228@.050.I stuffed this tickeler in my 410.
Lets just say its different.
