electronic speedo sender
Old Nov 3, 2005 | 08:36 AM
Nigel's Avatar
Nigel
I know this has been talked about at some point in the past but I can't find the answer.
I need an electronic speedo sender to fit a 78 f250 with a NP 205
Is there a later model ford part that fits? It will be hooked up to an autometer speedo.
Any one know a part number?
Old Nov 3, 2005 | 10:39 AM
ivanribic's Avatar
ivanribic
Nigel, I don't have a part number for you but I pulled mine off an 80's(?) E250 van. It was an auto tranny. The electronic sender had a cable plugged into the back of it as well and then 2 tires. I pulled the cable and just took the sending unit and it fits right into the 205 t-case. I don't know if you have a self pull yard there but if so just climb under a few of the newer vans/trucks and see if you can find one. Mine cost me $2. All you do is ground one of the wires and run the other to the signal terminal on the speedo. Works like a charm.
Old Nov 4, 2005 | 07:49 PM
Nigel's Avatar
Nigel
thanks ivan,
any one else have additional details unfortunitely we don't have a you pull it place around here.
Old Nov 8, 2005 | 08:14 PM
Scot's Avatar
Scot
Mid 90's PSD and a lot of the Ford cars used a bolt in 8 pulse per rev sender with no speedo cable. I got one at the Autozone and told them it was a 94 F250 PSD.
Flash635
Sep 22, 2015 03:33 AM
Greg5OH
Jul 13, 2014 03:20 PM
GoodiePop
Jun 2, 2014 10:37 PM
centralNH
26
May 12, 2014 06:42 PM
tjcprop
2004 - 2008 F150
Apr 18, 2014 06:59 AM
