05 Crew Vibration
Old Nov 3, 2005 | 07:39 AM
Fuji90120's Avatar
Fuji90120
Cool 05 Crew Vibration
Just wondering if anyone had experienced a vibration coming up through the gas pedal and the floor board. Dealer has already put shim kit to change pinion angle, but to no avail. It's constant regardless of the speed. Took a ride with the "shop foreman" at the dealer and he gave me a song and dance about the vibration being normal for the crew with General tires. Don't know what my next move is! Only have 700 miles.
Old Nov 3, 2005 | 10:16 AM
GOP's Avatar
GOP
Do a search for vibration in the search box. You'll see that its a well known problem, its also, one of the myriad of reasons Ford bought my 04' back. I suggest being meticulous about documenting everything, it might be important if you have to go through any legal or buy back process.
I also suggest you look for a different dealer if possible, and make sure to document his name and response that this vibration is normal on Screws. Good luck
Old Nov 3, 2005 | 11:56 AM
78Truckster's Avatar
78Truckster
Check the universal joint bearings. Are they staked in place or are they retained by cir-clips?
