rearend tag numbers
Old Nov 3, 2005 | 02:52 AM
Duckman101's Avatar
Duckman101
rearend tag numbers
i have a ford 9 inch out of a 77 f-150 tag# are WDM-BC2-7EC 3.00 9 3860 whats the gears and will it go in my 79 bronco? the tag is missing on my rearend now so i`m not sure what the gears in my bronco are. how do i go about finding out what they are?
Old Nov 3, 2005 | 06:12 AM
tellico racing's Avatar
tellico racing
Sounds like 3.00:1.
The 79 bronc probably has 3.50:1 or 4.10:1. Post the info on the bronco's data plate and someone can decode it for you to be sure.
Old Nov 3, 2005 | 10:28 AM
1975Ford's Avatar
1975Ford
Match the front axle tag gear ratio with the rear gears.
3.00 9 translates to a 3.00:1 gear ratio, 9 inch ring gear,
Old Nov 3, 2005 | 11:46 AM
Mil1ion's Avatar
Mil1ion
You are going to have to ident the Bronco gears to confirm actually what they are.
There a few methods, the best is to remove the diff and count the splines on both the ring gear & pinion shaft and then do the math.
This beats the guessing or possible gear replacements without the paper work saying so or having the proper tag.
Old Nov 5, 2005 | 11:15 PM
Duckman101's Avatar
Duckman101
thanks for the info thank you
Old Nov 5, 2005 | 11:55 PM
MBBFord's Avatar
MBBFord
Yeah, the F-150 has 3.00 gears, and 78 79 Broncos didn't come with anything other than 3.50 gears front and rear, and there is no way you could use a 3.50 up front with a 3.00 out back, unless you took out the front drive shaft or did a gear swap to match the other.
Old Nov 6, 2005 | 06:55 PM
Duckman101's Avatar
Duckman101
well are the splines the same? could i use my 3rd member out of my bronco now so all my gears are the same?
Old Nov 7, 2005 | 07:02 PM
MBBFord's Avatar
MBBFord
More than likely the splines are the same, but not 100% sure.
What's wrong with your Bronco 3rd member.
Old Nov 8, 2005 | 01:34 AM
Duckman101's Avatar
Duckman101
nothing i just cut the axle off goin down the road i was just woundering about splines before i took it apart. didnt want screw up the seals if i didnt have to
