Left turn shudder
Old Nov 2, 2005 | 07:44 PM
BACWUDZ's Avatar
BACWUDZ
Left turn shudder
Well lets start with I have 03 F150 7700 10.25 rearend limited slip (posi) ive been noticeing when i take left hand turns and accelerate i feel a slight vibration or shudder real quickly in the rearend is that ok? i plan on changing the fluid and adding the 8 oz. of additive should this fix the problem? or should i have the dealer fix it under warrenty? Any opinions?
Old Nov 2, 2005 | 07:48 PM
ford390gashog's Avatar
ford390gashog
what you describe is the common symptoms of a bad clutch pack in the rear diff. have it fixed under warranty. i had this issue in my 03 4 times.
Old Nov 2, 2005 | 08:29 PM
BACWUDZ's Avatar
BACWUDZ
Should i try to change the fluid? it has 90000mi and i just put a plow on it, here we go!
Old Nov 2, 2005 | 08:46 PM
BACWUDZ's Avatar
BACWUDZ
I forgot i notice it after my moose hunt i went through alot of water overflowing streams and beaver over flows where one overflow was deeep heard the rad.fan in the water #5 7 coils replced brakes palsating a skweek on the front suspension. how long should idrive with it the way it is?
Old Nov 3, 2005 | 05:52 AM
stuart1's Avatar
stuart1
If you filled it with water there would be no warranty on it.
Simple as that.
