lift needed???
Old Mar 31, 2002 | 05:07 PM
KirbyRicks's Avatar
KirbyRicks
Post lift needed???
I have a '78 f-150 4x4. I am getting 15"x8" Mickey Thompson wheels and 33"x12.5" BF Goodrich mud terrain tires. I don't know how much room, if any, I will have in the fenders after adding the big tires. I think that truck came with a 3 inch lift. Do you think I'll have enough room? Thanks.
Old Mar 31, 2002 | 05:31 PM
Cowboy_351's Avatar
Cowboy_351
lift needed???
If the truck has a 3 in lift already then you will be fine, but if it is stock height you will need to put some lift under it to keep the front wheels from rubbing
Old Mar 31, 2002 | 08:22 PM
bigf150's Avatar
bigf150
lift needed???
it will be fine with the lift
Old Mar 31, 2002 | 10:54 PM
79_ford_400_guy's Avatar
79_ford_400_guy
lift needed???
i have a 79 f-150 and it looks really good iwth a 3 in. body lift which is the way to go for a little cheap lift around 100 bucks and isnt too hard and i got 33 *12.50's on it it looks just right witht the fenders and everything
Old Apr 1, 2002 | 07:51 PM
jbulson's Avatar
jbulson
lift needed???
sure you dont need a 12.5 rim for a 12.5 tire???
Old Apr 2, 2002 | 09:25 AM
KJKozak2's Avatar
KJKozak2
lift needed???
I have a 78 F150 with a 3" susp. lift on top of the factory lift. I have 33x12.5x15's on it and have no problems. (I did just buy a Performance Products 3" body lift on ebay for $70 cuz I want bigger tires.)
Old Apr 2, 2002 | 03:56 PM
1970moose's Avatar
1970moose
lift needed???
3 inches is just right. It will look good too. Your rims are fine. You never want to put the same width rim as the width of the tire tread.
Old Apr 13, 2002 | 10:02 PM
66 Ranger's Avatar
66 Ranger
lift needed???
Old Apr 14, 2002 | 01:08 AM
KirbyRicks's Avatar
KirbyRicks
lift needed???
I ended up leaving the stock lift and getting 32x11.5 bfg all-terrains and 15x8 pacer wheels. It looks awesome. Thanks everybody.
Look for my gallery I'm working on to see 'em.
Old Apr 14, 2002 | 01:02 PM
mudder trucker's Avatar
mudder trucker
lift needed???
i have 33/12/50 rubber on my 79 bronco with no lift kit, and no rubbing anywhere under full articulation. mudder trucker.
