4 door supercab with 4 cyl ever?
Originally Posted by RangerPilot
What makes you want a four door four banger so bad?
As far as the four cyl. They have plenty of power and get good MPG to boot
My 99 with the 2.5L is pretty stong but the 2001 1/2 and newer with the 2.3L 16 valve are as good or better than the 3.0 and get a lot better MPG.
Th Supercab with the Four was not avaliable for Model years 2004 and 2005.
luckster I recall seeing only two in my area, back in 99, when I was looking for my new Ranger.
One was a Mazda the other a Ranger, both were loaded!!!! Gotta tell you, that engine sure looked mighty small, with all that truck behind it!!!!
After many test drives, over roads I was familiar with, with all the V6 engine/tranny combos, in my local mountainous terrian, I settled on the 4.0L, for the tasks I had in mind & havn't been dissapointed.
So, if you do manage to find a 4dr 4banger, I'd sure give it a good test drive, over roads you are familiar with, that'll stress it out pretty good & see if it'll measure up to your needs & expectations!!!!
That much truck behind the 4banger is asking a lot of it!!!! IMHO
Looking at the Ford México website. It appears that there is a 4 door Ranger with a 4 cylinder. http://www.ford.com.mx/vehicles/vehicles.asp?idModel=RAN
http://www.ford.com.mx/vehicles/know/photogallery.asp?idModel=RAN
If you click on the A tu Medida icon on the http://www.ford.com.mx/vehicles/vehicles.asp?idModel=RAN page, then click on the Motor section and select I-4. The 4 door is highlighted.
