'53 flattie starting trouble
Old Nov 2, 2005 | 09:36 AM
Narwhal's Avatar
Narwhal
Starting over on checking the basics on my Merc engine in the '53 F100. Checked compression on all cylinders, ranged from 80 to 95 with a cheap and old compression guage. BUT, no compression at all on #2. Stuck valve? Seems like it wants to suck a bit, but...
Stuck exhaust valve? Hole in piston? Safe to continue to try to start?
-Scott
Old Nov 2, 2005 | 11:20 AM
barry's Avatar
barry
Probably a stuck valve, common on Flatty's. Mine sat for 4 years and it had several stuck valves. I took the plugs out and sprayed PB blaster penetrating oil in and let it sit for a day. Finally got it runnung and then put some Marvel down thru the carb. Helps lube the valves.
Barry
50 F-1
Old Nov 2, 2005 | 11:40 AM
Narwhal's Avatar
Narwhal
Agreed. Got it running and it is doing well. I'll do the Marvel's also. Did you just pour it in the carb throat with the engine off or running?
-Scott
Old Nov 2, 2005 | 05:54 PM
barry's Avatar
barry
Did it while running, pouring very slowly! Just be prepared for a blue cloud. Great for bug control!! The more you run it, the smoother she'll run.
Barry
50 F-1
Old Nov 2, 2005 | 08:16 PM
g84t8f1's Avatar
g84t8f1
I Had A Mercury Flathead V8 In My 48 When I Got It.i Cleaned The Points Hooked Up A Electric Fuel Pump And Cleaned The Carb.i Was Amazed That It Started.it Had Stuck Valves.i Poured Tranny Fluid In The Carb. It Worked.i Wish I'd Kept It.
Art
