Charging Problems
Old Nov 1, 2005 | 06:03 PM
warren1994's Avatar
warren1994
Charging Problems
Yesterday my voltage gage drop to almost nothing, and my battery light came on. Istopped at a dealer they put a tester on it, said the alt. was bad. Put a new alt. on and going down the road the charge was a little high, thought it was just charging the batteries back up. At an Idle it is fine, but as soon as I hit the accelerator the needle damn near spikes. HELP please. What can I do?
92 F-250 w/7.3 non-turbo 2wd.
Old Nov 1, 2005 | 06:32 PM
RawPower's Avatar
RawPower
I have teh same problem... dies over night almost. barely starts after 18ish hours.
Old Nov 1, 2005 | 07:22 PM
Dave Sponaugle's Avatar
Dave Sponaugle
How high is it going?
Mine runs about 15 volts at high RPM when the batteries are low.
Check all the connections near the passenger side battery.
There are several connections that distribute the power to cab, motor and alternator probably on the front terminal of the solenoid mounted on the fender.
Also check the grounds to the engine, frame and cab.
Have the batteries load tested , this must be done one at a time with the positive wires unhooked.
Old Nov 1, 2005 | 07:37 PM
RawPower's Avatar
RawPower
batteries are brand new. ground going from pass cyl head to firewall is no there.
Old Nov 1, 2005 | 07:40 PM
wh336fire's Avatar
wh336fire
Does it have an internal or external voltage regulator ? I would check the voltage at the batteries while it is running to see if the test voltmeter matches the one in the truck .
Old Nov 1, 2005 | 08:30 PM
RawPower's Avatar
RawPower
im sure it does... volt meter says its low, truck has a hard time starting. all GP's just replaced
Old Nov 2, 2005 | 06:53 PM
Dave Sponaugle
Not sure about the 92 93 trucks, but the 86 has an external voltage regulator behind the passenger side battery. Little thin silver box with a plug that has 4 connectors in it. Voltage regulator may have died or the connector may be corroded.
Old Nov 2, 2005 | 07:19 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
On the PSD the regulator is attached to the back of the alternator.
KDAVID1
Feb 19, 2015 08:04 PM
dano89406
Sep 15, 2012 02:03 PM
Pocca
Electrical Systems/Wiring
Jul 25, 2007 01:31 PM
v8fiero
Aerostar
Dec 5, 2004 06:19 PM
earthworms
Oct 11, 2002 10:35 PM
