Ugh!! Charging problems?
Old Oct 7, 2002 | 08:31 PM
earthworms's Avatar
earthworms
Hello all,
Heres what I have a problem with. 1 year ago I bought an Optima battery. It now is a bad battery. I put a regular battery in it (750 cca). I also have a new alternator installed. At idle, it is charging at 16 volts. This isn't normal?? Could I have a faulty voltage regulator? I noticed this before I put on the new alt, and with the new alt it is still doing it. Prehaps this caused my Optima to fail. Possibly being over charged. Any ideas? I hope it is as simple as the regulator.
Thanks
Jake
Old Oct 7, 2002 | 09:05 PM
LxMan1's Avatar
LxMan1
Probably so, replace the regulator!!
Old Oct 7, 2002 | 09:32 PM
Mike W's Avatar
Mike W
16 volts is too high. At a higher rpm it is probably higher. Replace the regulator. I bet your headlights were nice and bright.
Old Oct 7, 2002 | 10:14 PM
jimlj's Avatar
jimlj
Over charging will fry your battery. Been there and done that.
Old Oct 7, 2002 | 10:27 PM
mearscn's Avatar
mearscn
I agree that it is probaly the voltage regulator. This would be a cheap swap out and would eliminate one of the possibilities if it didn't work.
Old Oct 8, 2002 | 01:34 PM
Bruiser_79's Avatar
Bruiser_79
Definately the regulator!!!!! Just happened to my '79 150. All the same symtoms - only mine was gettin pushed to nearly 18v and it popped a couple of bulbs in the truck. The battery would hiss after the truck was shut off.
Old Oct 11, 2002 | 08:05 PM
earthworms's Avatar
earthworms
Thanks for the info. I replaced the voltage regulator and here is what happend. My battery now is being charged at 14 volts and idle. (used to be 16 volts) As I rev the motor, it does't increase in voltage. I dont get it. What is the normal charge on a stock alternator? It has a 390 in it. What am I over looking? Any ideas?
Thanks,
Jake
Old Oct 11, 2002 | 08:18 PM
theonlybull's Avatar
theonlybull
if it's holding 14volts at idle, and doesn't increase much, then i'd say your good to go. looks like the regulator was your problem
Old Oct 11, 2002 | 08:40 PM
Mike W's Avatar
Mike W
14 volts is perfect. It may vary slightly with temperature.
Old Oct 11, 2002 | 09:07 PM
earthworms's Avatar
earthworms
Shouldn't my voltage increase as I rev it? It stays between 14 volts to 14.10 volts. I always thought the more you reved the motor the more the alternator puts out.
Old Oct 11, 2002 | 09:47 PM
SeaDooPhil_78's Avatar
SeaDooPhil_78
Post Ugh!! Charging problems?
The higher the engine RPM's, the more Current (amps) the alternator
is able to produce. Voltage should stay close to 14 volts regardless
of the RPM's if the regulator is doing its job. Anything over
14.4 volts for an extended period of time is too much voltage
output for an alternator. I prefer to use a good quality
digital meter to measure this.
Hope this helps,
Phil
Old Oct 11, 2002 | 10:35 PM
White_Knight's Avatar
White_Knight
energizerexplorer
Jul 14, 2013 04:38 PM
rustyoilpan
Nov 17, 2006 01:26 PM
Meilichios
Electrical Systems/Wiring
Jan 4, 2005 07:00 AM
Merlin68F-100
Nov 13, 2003 10:37 AM
Jrock909
Sep 25, 2003 11:54 PM
