starting problem
Old Nov 1, 2005 | 06:01 PM
lgower's Avatar
lgower
starting problem
98 5.0 explorer,every so often the car wont start,spins over great,but nothing,when it does start it takes a while to get going,barely runs,then everything is fine,changed the fuel filter,same problem,any ideas,thanks alot
Old Nov 1, 2005 | 06:27 PM
srercrcr's Avatar
srercrcr
Some Explorers, including mine lately, have experienced INTERMITTENT failure to kick over....meaning everything is fine for weeks/months, then one day it cranks just fine, but doesn't kick over or even seem like it wants to try. You'll need to read up on past posts cause different people have had different luck with EEC relay, fuel pump relay, bad connection at the PCM. Mechanics won't be able to help unless it's doing it when in their hands. Someone recently told me that when you first turn the key and the dash lights come on, check to see if the "check engine" light is on. If not, try to start it. If it just cranks, that's a sign it has something to do with the PCM or connections.
