Transmission Flush
Old Nov 1, 2005 | 05:15 PM
bnewkirk's Avatar
bnewkirk
Transmission Flush
When I picked up my Expedition from the dealer today after an oil change they recommended that I have the transmission flushed as well as the replacing the power steering fluid. I see in the service guide that at 30,000 some transmissions are listed to have the fluid changed.
How do I find out which transmission I have?
It is a 2003 4wd with the 5.4 engine. I have 48,700 on the truck.
Thanks
Old Nov 1, 2005 | 05:46 PM
ford390gashog's Avatar
ford390gashog
you have the 4r70w tranny. it should be changed every 30,000 miles.
Old Nov 1, 2005 | 08:36 PM
skier-24's Avatar
skier-24
How much did they want to flush the trans?
Old Nov 1, 2005 | 08:45 PM
88FordF-150's Avatar
88FordF-150
If you get a tranny flush make sure it is an inline tranny flush not a hose going down threw the tranny filler tube. If you get the flush wre you put the flush tube down threw the tranny filler tube it does not clean as well because it sucks the fluid out and then mixes withe the new fluid and goes right back down in.
Old Nov 1, 2005 | 11:27 PM
calviroman's Avatar
calviroman
I thought all the 5.4 expy's for 2003+ had the 4R100?
Old Nov 1, 2005 | 11:30 PM
ford390gashog
no. the 4r100 is not used in the expy anymore. i am not even sure if the 4r100 is used in the f150
Old Nov 2, 2005 | 03:00 AM
bnewkirk's Avatar
bnewkirk
Looking at my Scheduled Maintenance Guide it says that a 30k change is needed on AX4s, 4F40N, 4R100 and 4F27E. The 4R70W is not included in the list.
Maybe my book is not up to date??
Old Nov 2, 2005 | 03:30 AM
ford390gashog
mine says the same thing. either way 30k is a good interval for any tranny.
Old Nov 2, 2005 | 04:39 AM
trike1946's Avatar
trike1946
If you tow a lot, change it at 25k.
Old Nov 17, 2006 | 08:44 AM
verticalrich's Avatar
verticalrich
i have had the dealer flush mine twice, 187000 miles, shifts hard
Old Nov 17, 2006 | 09:30 AM
Darth Baiter's Avatar
Darth Baiter
Found this after searching under "which+transmission" :
Go to the Vehicle Certification Label located on the driver's door. Under the barcode, look for "TR". Below "TR" will be the code for the transmission type. "E" = E40D (pre 4R100), "U" = 4R70W.
Try the search feature for answers other than the above.
Old Nov 18, 2006 | 12:14 PM
nobrandx's Avatar
nobrandx
I don't always flush my tranny, I always drop the pan and replace the filter also, flushing is kinda like changing oil and not changing your filter, it is a good idea though because fluids get dirty, etc. but I flush every 15K, and put in a new filter and fluid every 30K, overkill is good besides it's cheaper than a 3-5k Tranny
Old Nov 18, 2006 | 12:22 PM
houlster's Avatar
houlster
I wish I could search...
Old Nov 19, 2006 | 02:41 PM
verticalrich
ive heard from several transmission guys that repacing the filter is not neccesary
it is not a disposable paper filter like all the others
when they flush the fluid it is pumped in reverse to clean the filter
thats my understanding anyway
CollinsCD
Dec 5, 2013 05:52 AM
beeser
Sep 30, 2013 03:37 PM
JonArmy
Oct 30, 2011 09:17 PM
B 3000
Escape & Escape Hybrid
Feb 18, 2010 06:41 PM
Jimmygunz3
25
Nov 29, 2006 03:36 PM
