Speedometer calibration HELP!!!
Old Nov 1, 2005 | 02:18 PM
CMBCBELL's Avatar
CMBCBELL
I have a 2006 Lincoln Mark LT. Lifted 6 inches w/ BFG 315/70/17 tires and also
installed 4.88 gears. Problem is speedometer needs calibration. Guessing it is 20 -25 mph off. Have already called calibration shops in town to no avail. Called dealer said Superchips has programmer. Called Superchips they said 2005 would not work call back after 1st of year. My question is this - are their any differences between the 2005 and 2006 where as a Superchips programmer would not work to help alleviate calibration problem? Any other products? Ideas?
Engine is a 5.4.
Any help would be greatly appreciated.
Thanks,
Stuck in Phoenix
Old Nov 1, 2005 | 03:24 PM
xc7edge's Avatar
xc7edge
If you can find a programmer, use it w/gps and it wont take long at all to set speedo.
Old Nov 1, 2005 | 03:57 PM
FS-150's Avatar
FS-150
If you don't already have a programmer, I thought the dealership could do it for $40-$60.
Old Nov 1, 2005 | 05:50 PM
Carnivore's Avatar
Carnivore
your best bet is to buy a programmer. By the way, no way its off that much. Maybe 5mph off at the most, but in order for it to be of 20 mph, you would have to have 50 inch tires. Go here and it will tell you exactly how much your speedometer changed from your stock tires. http://www.miata.net/garage/tirecalc.html
Old Nov 1, 2005 | 08:17 PM
xtrm1stang's Avatar
xtrm1stang
dealership should be able to do it, but with teh taller tire and gear you wont be too far off
btw how bout some pics?
