Brake Drum Puller
Old Nov 1, 2005 | 12:15 PM
jethro1's Avatar
jethro1
Brake Drum Puller
Where can I get a brake drum puller? The drums on my '64 F-100 are good and stuck (rust). A puller is all that's going to work. I'm having some trouble finding one.
Old Nov 1, 2005 | 01:54 PM
William's Avatar
William
PB Blaster on the axle flange, patience, after a few days soaking, heat the flange area while tapping on the outer drum. These are available new so if you cannot get it off its OKAY to torch it!
Old Nov 1, 2005 | 04:04 PM
nealjpage's Avatar
nealjpage
I've rented them before from rental houses. It's essentially a big gear puller with three jaws. Some auto parts stores have them, too.
Old Nov 2, 2005 | 10:16 AM
truckfarmer's Avatar
truckfarmer
Which drums? The fronts are pressed onto the hubs but the rears should slide off if the shoes are backed off enough.
Old Nov 2, 2005 | 11:05 AM
jethro1's Avatar
jethro1
I need to remove all four. They are rusted on. I'm working on the ground. No lift. Backing-off the shoes is difficult. I'm hoping to pull the suckers off.
Old Nov 2, 2005 | 03:52 PM
garbz2's Avatar
garbz2
As Greg pointed out the fronts can have the budwiser clydesdales pulling on them and they will not come off. Remove the spindle nut and pull the entire hub/drum off the fronts.
The rears can be jimmeyed off but they need to be backed off. I have gotten real stubborn ones of by hitting the pins with a grinder at the backing plate and then pulling. Last resort is break the drum and then pur new ones on. Chances are if it has that much of a ridge its beyond spec for cutting.
Garbz
marine1200
1947 and Older Ford Trucks
23
Aug 16, 2012 07:42 PM
nlareau
Apr 21, 2011 08:13 AM
trike1946
Aug 22, 2009 12:44 PM
gary_b
Oct 16, 2006 07:46 AM
kyoung
Sep 25, 2006 04:47 PM
