alternator
Old Oct 31, 2005 | 04:22 PM
screwloose2's Avatar
screwloose2
alternator
looking to change out my old externally regulated alternator to a one wire 100-150 amp (internally regulated). It needs to bolt to a early 302 ford passengers side , anyone know of any late modle swaps or a reliable vendor to get one from . It needs to put out 50 or more amps at idle .
thanks jeff
Old Oct 31, 2005 | 04:32 PM
Okiedokie's Avatar
Okiedokie
I made a spacer and used a gm one wire.
Old Oct 31, 2005 | 04:35 PM
ford390gashog's Avatar
ford390gashog
50 or more amps at idle? so you will need a high idle or go to a smaller pulley on the alternator.
Old Oct 31, 2005 | 05:25 PM
screwloose2
alternator
Hay Joe tell me more about the GM alternator . I realize that i can change the pully but i would rather get a larger alternator that will do the job .
thanks jeff
Old Oct 31, 2005 | 06:15 PM
g84t8f1's Avatar
g84t8f1
Vintage Sacramentsells A Single Wire Voltage Regulator That Bolts To The Back Of Your Ford Alternator.just One Wire.it Is 38.00 In My Book.
Art
Old Oct 31, 2005 | 07:46 PM
4tl8ford's Avatar
4tl8ford
Jeff
Check in with your local ambulance company, they have some high output alternators in their rigs.
Old Oct 31, 2005 | 08:30 PM
51ford fan's Avatar
51ford fan
Wink
Look in the phone book for an independent alternator, starter repair business. I went to some of the local parts stores looking for a high output alternator. All the sales people could find for me were the 65 amp units that there computer screens showed. I found an independent rebuilder and he built me a 105 amp unit while I waited and warranted it for a year. The difference was like night and day, it's really nice to find someone who knows what they are talking about.
Old Oct 31, 2005 | 08:51 PM
Okiedokie's Avatar
Okiedokie
Jeff, when I installed the gm unit I did so to get one wire hook up with no external regulator. I believe that now you can get the same in Ford unit. If you do want to use a gm unit, you can by fabbing a spacer to match up with Ford bracket. seems like I had to make a bolt diameter adjustment also. Tomorrow eve I will look close and give better info if you like. Joe
Old Oct 31, 2005 | 09:17 PM
LEckart's Avatar
LEckart
I used the Tuff Stuff one-wire Ford 100 amp alternator on my 302. It is chrome and is pricey, $179.
Old Oct 31, 2005 | 11:16 PM
imlowr2's Avatar
imlowr2
Most of my friends are using the GM one wire. It's cheaper than a Ford alternator and works just as well. I'm still using the old style with the external regulator. I may change it out later, but I just put chrome housings on mine and rebuilt it. Kinda like the old ones too and don't know much about the one wire style or wiring the one wire?
Old Nov 1, 2005 | 09:50 AM
Okiedokie's Avatar
Okiedokie
Jeff, look here www.performancedistributors.com and check out their alternators. Joe
Old Nov 1, 2005 | 11:38 AM
Jag Red 54's Avatar
Jag Red 54
I went through this last July. I bought a chrome rewired Ford one-wire. It did not work. I took it back twice to the manufacturer before I found out the problem was the custom billet pulley. It was slipping so the alt was not turning fast enough. If I was going to do it again, I would go to the local auto-electric shop and have my existing unit rewired to a one-wire with 100 amp oputput. It will be cheaper and save you the fabrication/installation headaches. Good luck, Jag
Old Nov 2, 2005 | 06:01 AM
screwloose2
alternator
thanks everyone , I found a local shop that is doing one for me .
Jeff
