I had the same problem where the mounting holes weren't lined up with the MAF hole, and one of the inserts got pulled out.
I was also told the new intake tubes would be done three months ago. I believe the AFE Stage 2 could be a good after market filter, but expected better than this for $475.00!
Having troubble with AFE stage 2 intake, 2 engine codes were produced. EGR flow excessive and IAT not working. Called AFE and got message they are working on it. I called back to see how to return whole thing and have not heard back yet. Also while running AFE got 2.5 mpg less. I am running stock filter box now and mpg went back up but still getting IAT code when download engine codes. I think it may have burned up the sensor.
Driving the same style as before I added mine and have picked up 1-2 mpg...1st tank of fuel through with the stage 2 resulted in 17.35 mpg...and that was with probably a good 45-60 minutes total idle time at 1000rpms while warming the truck up. Still no check engine light.
