Check your grounds
Old Oct 31, 2005 | 05:17 AM
HighboyMac's Avatar
HighboyMac
Smile Check your grounds
I have been trying to chase down the cause of my lopey idle. I suspected that the cam in the 429 was stock. I was right. I posted a question to the appropriate engine forum looking for answers. Why is it that the simple crappola always is the cause? I was tinkering around under the hood while thinking what could be the cause. Timing is spot on... Carb is adjusted spot on. New plugs and wires cap and rotor. Brand new distributor. Then it hit me....dang that ground cable loooks awful. The battery clamp is crappy and the connection at the passenger side cylinder head is pretty gross as well. I replaced the cable and cleaned the connection at the block. Shebang.....idle issue solved. Dash lights are brighter...amp gauge shows more charge...headlights are brighter...and overall has more poop off the line. I suspect that the poor ground was muffing with my electronic ignition. Repeat after me...all together now...check the ground first.....check the ground first. Methinks I will add a couple ground wires as well. One to the frame and one to the body in addition to the connection on the block.
Cheers.
Bill.
Old Oct 31, 2005 | 06:53 AM
kopfenjager's Avatar
kopfenjager
I had a problem with hot starts awhile back and it was the same culprit. Bad connections. Easy fix, ounce you figure it out.
Old Oct 31, 2005 | 12:55 PM
Pocca's Avatar
Pocca
Yea, basics. And on a similar topic, those decades old crusty rubber harness connectors (they get crusty in our dry heat) sometimes harbor relatively highly resistive current paths from mud and gunk. If you think about 13V trying to drive .5A into a little light a measily 10ohms of crud consumes more than a third of the power. Low voltage is very safe, but not very efficient from a power standpoint. I'm on an electrical crusade with a 78 Supercab known as Fang. So far he's still a heathen, but he will convert.
Old Oct 31, 2005 | 01:53 PM
Mil1ion's Avatar
Mil1ion
May I suggest posting the *solution to problem update* to what the cause was in your original thread ?
Just the solution to the problem... of the numbered question it was.
This way it will stay with the original thread
Glad you solved it.
Is there not braided ground cable attached from the intake or block to the firewall ?
