Offroad & 4x4
hey ivan (quick ? )
Old Oct 30, 2005 | 09:38 PM
f150_514ci's Avatar
f150_514ci
hey ivan (quick ? )
did you get the rear disc's that were for e-brakes or not ?
thanks
Old Oct 30, 2005 | 10:06 PM
ivanribic's Avatar
ivanribic
No, they are non e-brake. If you go through the same guy I got mine from (www.blackbirdscustomtrucks.com) he does offer them with e-brake but they're more $$ and he can't always get them right away due to the rarity of the Eldorado calipers. I chose to use Hondas as wheel chocks.
Old Oct 30, 2005 | 11:02 PM
f150_514ci's Avatar
f150_514ci
ok thanks was just wondering if they hooked up to the factory e-brake cables
Old Oct 31, 2005 | 07:11 AM
bremen242's Avatar
bremen242
Those kits look to be pretty high quality. There is only thing that bugs me, though. All ebrake calipers that I see people using are the Elderado calipers. On Pirate, at least, anyone says that those calipers don't hold when the ebrake is on.
With all these 4 wheel disc vehicles we have now, why are we using those crappy ebrake calipers that don't work?? I want to retain my ebrakes when I do my 61.
Old Oct 31, 2005 | 08:52 AM
Thomasm67's Avatar
Thomasm67
On trucks about a month ago they showed a product the fit on your Tcase it was a brake maybe a Ebrake. It would fit on your shaft then you put your DS on. Can't remember what the name was tho.
Old Oct 31, 2005 | 12:31 PM
ivanribic's Avatar
ivanribic
Yeah, Jesse sells those at www.highangledriveline.com. My only issue with those is if you pick up one wheel and you're not spooled they're useless. Like if you set your parking brake and needed to change 1 tire on a slope . . . well you're screwed.
FWIW, last time I talked to Randy at Blackbirds he was in the process of building an e-brake add on for the kits he sells. It's a completely independant unit that bolts right to the caliper bracket he already sells. Once he has them in production they can be added to a disc brake kit and will never depend on parts availability of the Eldorado calipers.
Old Oct 31, 2005 | 01:11 PM
f150_514ci's Avatar
f150_514ci
any idea when he is going to have these avaliable to the public ?
Old Oct 31, 2005 | 01:35 PM
ivanribic's Avatar
ivanribic
Nope. Next time I get by his shop I'll ask him. He does a lot of custom stuff like roll cages and crap like that for people and he's the only guy there so he's pretty swamped. I do know that he told me the e-brake kits would remain the same price, just that they'd use his new brake lever rather than the Eldorado calipers and he'd sell them seperately as well.
Old Oct 31, 2005 | 07:06 PM
mustange70's Avatar
mustange70
If your are doing a read disc convo on a 9" find a late 70's lincoln and rod the rear discs and calipers. This is what i'm in the process of doing (if i ever get around to starting it), and i have everything to do it (pretty much a straight bolt on conversion other than having to get the axle flange machine downed 1/4" to clear the 94 4x4 front rotors), and a plus is that i could use the exact same calipers that the front of my 82 flareside uses, but i lose the ebrake, and after some testing i found that the ebrake on these works quite excellent (i have pictures of everything in my one gallery).
Old Oct 31, 2005 | 08:36 PM
bremen242's Avatar
bremen242
So the lincoln versailles's calipers have ebrake levers on them??
It would be a good conversion, but it won't work with an 8 lug axle.
Old Nov 1, 2005 | 11:52 AM
f150_514ci's Avatar
f150_514ci
great thanks for the info
Old Nov 1, 2005 | 04:05 PM
bremen242's Avatar
bremen242
Does any one have any close ups of superduty calipers?? I'm wondering if they have a drum ebrake, or if it is part of the caliper...
Also, anyone any difference between the mid 70s ebrake caddy calipers and the mid 80s ebrake caddy calipers?? Seems like the mid 80s ones would be easier to find..
Old Nov 1, 2005 | 04:46 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
i would imagine the drum inside, every newer model disc ebrake ive seen is like this....you get much better holding power
Old Nov 1, 2005 | 07:20 PM
mustange70's Avatar
mustange70
Yep the lincoln's calipers have the lever on em'.
Yeah does anyone have anyclose ups of the rear disc setup on the superduty's?
Old Dec 12, 2005 | 12:39 AM
f150_514ci's Avatar
f150_514ci
hey ivan did you talk to randy yet to see if he made those e-brake add ons avaliable to the public yet ? just curious
thanks
