Im geting ready to put a C6 with a shift kit into a 1966 F100 with a 352 , Presently I have a 3:54 rear end ratio which even with 30 inch tires will run the rev's pretty high, I do some towing of my boat which is arounf 2,200 lbs tow weight, I Am thinking about droping the rear ratio down to 3.08 gears, my question is what stall speed Tq converter should I use. This is not a race car it's a dayly Driver and used to get to the lakes sometime's. I presently have a 3 speed overdrive manual that is losing 2nd gear and the clutch is going also. I have not liked the clutch on the boat ramp and am looking forward to the auto. i just want to get the correct converter for the job. I rarely see over 3000 rpms.
I thank you in advance for any info you can share as Stall speeds is somthing I know nothing about.
The stall speed is really going to depend on the cam and build of your engine. When people install a converter with a higher stall it's to allow the engine to get into an RPM range where it's producing more power before it stalls. "built" engines with larger cam profiles might not start producing power until 2000,rpm 2500, 3000 or with race built motors even higher. Therefore the stall speed is matched to the RPM where the cam is producing power. I'm guessing, based on your statement about rarely seeing over 3,000rpm that you're not running a really built setup. If the motor is stock, or relatively close to stock go ahead and run a stock converter, which will probably stall between 1200-1500rpm. If you have an aftermarket cam post up the cam number or profile here and we can tell you which stall you'll need. Hope that helps.
Thanks a bunch, no shes basicly stock, holley 500 cfm 2v, dual flowmaster, and pertronics ing,someday maby a set of headers and a performer intake with 600 holley but thats about all. not a hotrod by any means. havent desided yet, I have a 460 and C6 still at my storage in Sac but wont be grtting that up hear till spring and it will need a rebuild, if I do a hotrod motor that will be the one.
You can get away with a stock converter. Converters need to be matched to the cam in the engine. You could even run a coverter with a lower stall and that would help cut rpms ant cruise. around 300-400rpm, for a mileage/towing converter.
I wouldnt buy a used stock converter, buy a new stock stall converter and you wont risk having to pull the tranny after getting it in. Been there done that. Good Luck with it.
Oh this would be great, what speed stall converter would I ask for then ?
most of the parts store's I have seen online list a stock converter, where would I find a lower one ?
I deal with oregon performance transmission. They have a store on e-bay. They were realy helpful in helping me get the right parts for my trany rebuild. And yeah you can always have to much of a good thing. If you don't have the torque down low to pull the stall than it can hurt more than it helps.
