1966 - 1977 Early Broncos
Testing Ignition coil?
Old Oct 30, 2005 | 09:09 PM
78half-tonhotrod's Avatar
78half-tonhotrod
I've got a 1970 bronco with 302 and the ignition is all stock. It will crank over but I'm not getting any spark off of the coil. I was wondering how to test the coil to see if its good. Do you check continuity or resistance with an ohmeter? The coil draws power from the igntion switch, right? The switch seems to be messed up, it won't go to the accessory position and doesn't spring back like it should. How much voltage goes to the coil from the switch with the key in the on position? Thanks for help.
BTFordGuy302
36
Jun 4, 2015 01:27 PM
puroford
Jul 5, 2011 09:04 AM
tdmcnitt
Apr 18, 2011 12:04 PM
myklstrng
Electrical Systems/Wiring
Oct 23, 2010 12:01 AM
apalo187
Escape & Escape Hybrid
May 5, 2010 08:56 AM
