Compression level?
Old Apr 16, 2002 | 09:10 PM
Mil1ion's Avatar
Mil1ion
Compression level?
Old Apr 21, 2002 | 02:13 PM
WildOats's Avatar
WildOats
Post Compression level?
What would the cylinders compression be on a brand new 360 engine for a 76'?
Old Apr 21, 2002 | 02:20 PM
Mil1ion's Avatar
Mil1ion
Compression level?
Probably about 140-150 psi
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
Need to decode your 78 Truck data plate? click here
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven!
[/font]
Feel free to visit my website.
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color =red] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
Old Apr 21, 2002 | 02:28 PM
WildOats's Avatar
WildOats
Compression level?
That's not what I wanted to hear. Our compression levels are between 118-120 on all but one cylinder, #6, which is at 109. We've got a big problem, then.
Old Apr 21, 2002 | 02:34 PM
Mil1ion's Avatar
Mil1ion
Compression level?
[updated:LAST EDITED ON 21-Apr-02 AT 03:39 PM (EST)]Why ,Is this new rebuilt engine?
Or a crate engine.
The lowest cylinder should be within about 90% of the highest
ie: 130psi High and 117 psi Low
I'll try and find the exact value for you.
EDIT:
And the correct answer is 140 psi
[/font]
Old Apr 21, 2002 | 03:02 PM
WildOats's Avatar
WildOats
Compression level?
It's a new rebuilt. My father and I rebuilt it complete. Ours was also bored 30 over. Now, if the psi should be at 140 and ours is at 109, 118-120-- isn't that too low for a brand new engine? What could be causing this?
Old Apr 21, 2002 | 06:45 PM
Vampiro's Avatar
Vampiro
Compression level?
maybe bad rings or a leak somewhere?
Old Apr 21, 2002 | 08:56 PM
Jermafenser's Avatar
Jermafenser
Compression level?
Did you test it right? How did you test it?
Old Apr 21, 2002 | 09:09 PM
dvlinnell's Avatar
dvlinnell
Compression level?
Have you tried to fire the engine? Did you prime the oil pump? With out first getting the lifters to pump up, you probly wont have much compression.
Old Apr 21, 2002 | 09:16 PM
jbulson's Avatar
jbulson
Compression level?
That is a very GOOD Point!
Old Apr 21, 2002 | 09:19 PM
sauerf100s's Avatar
sauerf100s
Compression level?
I think you're wrong about the lifters. They open the valves, not close them. Think about it.
Old Apr 21, 2002 | 10:32 PM
blaxuede's Avatar
blaxuede
Compression level?
What's the compression supposed to be for a 351 C 2V? I rebuilt my engine, had my heads shaved. There's no carbon on the heads or anything and all the cylinders were up around 160-180psi..
Old Apr 22, 2002 | 10:23 AM
dfisher1's Avatar
dfisher1
Compression level?
Wild,
Just answered your other string. An 8.0:1 compression ratio should yield about 125 PSI. If the lifters are not pumped up before valve adjustment your wasting your time.
Is the Cam stock? If not, what is your lobe offset? This can effect your compression test. The smaller the offset, the lower the compression. I think 109 degrees is factory. Low compression will screw up the emmisions test. Readjust the valve after you've primed the lifters. A 5/16 or 8mm socket will drive the oil pump driveshaft on a 302. I don't knot the 360 size right off hand.
KingFisher
Old Apr 22, 2002 | 11:27 AM
beartracks's Avatar
beartracks
Compression level?
In order to get an accurate compression reading you would want the lifters pumped. After cranking a while they should get there. You also have to prop the carb fully open and remove all the plugs. It can make a big difference in the reading. If the enigine hasn't been fired the rings haven't had a chance to seat either.
Bear Tracks
P.S. A lot of cranking is not a good thing for a new engine.
Old Apr 22, 2002 | 12:22 PM
dfisher1's Avatar
dfisher1
Compression level?
All,
If the valves are adjusted before the lifters are primed then they will remain collapsed. The valves must be loosened and the the lifters can be "pumped up".
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
