Trying To Identify
Old Oct 30, 2005 | 12:25 PM
DANDEE1996's Avatar
DANDEE1996
Trying To Identify
Does Anyone Know The Difference In The Width Of The Intake Manifold On 351m And 351c?
Old Oct 30, 2005 | 12:57 PM
Bill_Beyer's Avatar
Bill_Beyer
Roughly an inch and a half. The valley width on the 351M/400 is 8.5". The width on the 351C is 7" give or take 1/32".
Old Oct 30, 2005 | 01:14 PM
sparky69's Avatar
sparky69
hard to get an accurate measurement, but i measured a 351m/400 intake's width at approx 12 1/2". took the measurment across the TOP of the intake (widest part). from the top of the gasket surface of one side to the same location on the other side. i don't have a 351c intake to measure, but i know they are narrower because you can run a 351c intake on a 351m if you use spacers. this is assuming that the intake has not been milled/shaved to compensate for milling the deck. i'm sure the one i measured has not been. hope this helps.
Old Oct 30, 2005 | 01:16 PM
DANDEE1996's Avatar
DANDEE1996
that would be the measurment of the top of the block, correct?
Old Oct 30, 2005 | 01:19 PM
sparky69's Avatar
sparky69
i believe that measurment would be the distance between the top gasket surface of the heads, not the block
Old Oct 30, 2005 | 01:32 PM
Bill_Beyer's Avatar
Bill_Beyer
Valley measurement is taken between the lowermost portion of the head sealing surfaces after they're mounted on the block.
Old Oct 30, 2005 | 01:40 PM
sparky69's Avatar
sparky69
i got approx. 8 3/4" between the lower part of the head sealing surface on the 351m/400 intake that i have. it is not installed on the motor tho...
Old Oct 30, 2005 | 01:46 PM
DANDEE1996's Avatar
DANDEE1996
thats great folks that is what i needed to know
Old Oct 30, 2005 | 01:48 PM
Bill_Beyer's Avatar
Bill_Beyer
Well on the 400 which is sitting on the stand in my garage it's just a fuzz over 8.5" which corresponds to the measurement of 8-17/32" on the E'brock website.
Old Oct 30, 2005 | 01:52 PM
DANDEE1996's Avatar
DANDEE1996
ok, so thats 8-17/32" for the 351m/400 and 7" for the 351c. got it thanks.
