tuning
Old Oct 29, 2005 | 10:03 PM
Cur3's Avatar
Cur3
Arrow tuning
afetr u install an exhaust or air intake or any pormformance part will tunign you car help maximize ur horse power? or will u ahev the same if u dont haev it tuned and dynoed
Old Oct 29, 2005 | 11:04 PM
4.0 Beast's Avatar
4.0 Beast
dont know about explorer's in general, but i know tuning doesnt make a difference on my mustang. i had a 2000 GT with aftermarket exhaust including an x-pipe, and a cold air intake system.....and had it dyno'd. tuning only helps if you change things like the MAF sensor, or the size of the throttle body.......
Old Oct 30, 2005 | 01:38 AM
CobraXP's Avatar
CobraXP
Neither exhaust or intakes need tuning afterwards unless you did something major. Easy way to reset it though is to unplug the computer. Take the 10mm bolt out of the wiring harness to unplug it. Some say you hhave to disconnect the battery to reset the PCM, but you can just unplug the PCM and you won't loose radio presets, clocks, etc.
