1999 E150 Wont Idle
Old Oct 29, 2005 | 04:26 PM
jbaum's Avatar
jbaum
1999 E150 Wont Idle
I have a 99 E150 that will not idle when it is cold or hot, it will die if you let off of the pedal when slowing down. I have checked and there are no codes up.
I was wondereing about the IAC, can anyone tell me where it is located and what it looks like, And how to clean it, or offer other info on what the problem might be.
Thanks Jeff
Old Oct 29, 2005 | 04:52 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Jeff, to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 30, 2005 | 03:48 AM
Dannym's Avatar
Dannym
It is located where the throttle butterfly valve is, inside a block between the big air hoses and the intake manifold.
I saw somewhere that they don't recommend trying to clean it. I don't know how true that is though.
