Glowplug replacement
Old Oct 29, 2005 | 02:26 PM
bridgeman's Avatar
bridgeman
I got into the drivers side valve cover and replaced the glowplugs, I could not find any that seemed bad after testing them with an ohm meter but replaced them anyhow, my luck is that the bad ones will be on the passenger side. I have a couple questions, can you test to see if there is a bad one without getting the valve cover off, and when I removed the old ones they were covered with oil is this normal? Thanks in advance for any input.
Old Oct 30, 2005 | 09:47 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You can ohm the plugs with the valve cover on.
https://www.ford-trucks.com/forums/s...d.php?t=421710
kev03
Sep 25, 2014 07:36 AM
lunatech
Jul 7, 2014 08:51 PM
Txlranch
Apr 6, 2012 12:15 AM
lawngrease
26
Nov 2, 2008 07:56 AM
Duane99
Apr 3, 2006 04:28 PM
