I know of some guys running 9.5 on 87. but the timing cant be advanced more then 12*. aluminum heads allow you to run more compression then cast heads before you get detonation. make sure your wires are routed properly and are good quality wires. also becarful what plugs you run as well. whats this motor in?
The motor is in a go-fast baja prerunner bronco. Right now it's a stock motor
(351 iron heads) and it runs on 87 octane. The motor is old and tired and I'd
like to rebuild it. I'd like to build a strong high rpm motor but I must still burn
87 octane.
I want to build a 408 stroker with some good aluminum heads but I need to
decide how much CR I can handle with 87 octane so I can select heads and
determine how much dish the pistons will need.
I seen some running 9.5 on 87, low power and poor milage, they swapped to 92 in the same engine and better milage and more power. I would agree with sticking around 9.0. I'm running 9.5 and 89 octane easy with plenty of power, haven't tried octane swaps to see a difference though.
Thx for the info. I don't mind paying for higher octane but a few times a
year I end up in remote areas of baja where they only have 87 octane.
Ford has a 351 crate motor listed with the Z304A high flow heads, 9.0:1,
410hp, 417 ft-lbs. Part M-6007-Z351. Looks perfect except I'd want to
use it with factory EFI. Seems like that motor should run on low octane
as long as the timing is not too advanced?
