Problem with transfer case
Old Oct 29, 2005 | 11:46 AM
Ford classic's Avatar
Ford classic
Unhappy Problem with transfer case
I have a 1976 ford f-150 with a np203 transfer case. It has been converted to part-time now and if I don't hold back on the shifter it sounds like gears grinding and wants to engage. It does this from a stand still and somtimes when I am just driving down the road. Is there a rebuild kit I can get or what is the best thing I should do to fix this problem. Is this an easy thing to fix myself or do I need to have a mechanic fix and spend lots of money. The transfer case only has low lock and high lock. I think that is all I know, if anyone has an answer for me I would appreciate it.
Old Oct 29, 2005 | 12:28 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 29, 2005 | 04:18 PM
easydoesitmikey's Avatar
easydoesitmikey
I would like to hear more about these conversion kits.Costs,who makes it,difficulty of installtion,durability etc.I have a 78 F-150 with a 203.Eventually I would like to swap it for a 205 when I can afford it.In the mean time I been considering the conversion kit.
Old Oct 29, 2005 | 08:29 PM
witdog2020's Avatar
witdog2020
sounds like an unfinished job?
I believe its more than just installing lockouts to make it a part time 4x, I think theres a pin that needs installed in the T/C to complete the process, its sounds like yours is missing? or malfunctioning?
