1978 - 1996 Big Bronco
Another Roll Bar Question
Old Oct 29, 2005 | 01:02 AM
Chrisconsin's Avatar
Chrisconsin
Would this fit newer broncos mine is a '95... If not what are the diffrences?
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
-chris
Old Oct 29, 2005 | 01:35 AM
Chrisconsin
if the link doesnt load just type in "bronco roll bars" it says it will fit 87-91.
is there a height diffrence in those years to the newer ones.
Old Oct 29, 2005 | 02:53 AM
greystreak92's Avatar
greystreak92
The difference is the fact that in 1992 Ford changed the rear seat outboard passenger seatbelts to shoulder harnesses. There probably isn't enough clearance between the roll cage and the top for the seatbelts to mount properly. The "fix" for this problem would be to relocate the seatbelt mountings to the bars of the cage itself by drilling holes and welding grade 8 Nuts to the cage at the same point where the seatbelts SHOULD mount.
Old Oct 29, 2005 | 08:55 AM
94 XLT White/ Silver 302's Avatar
The height is the same for 80-96 you don't want a 78-79 roll bar the floor pans were different so the roll bar will set to low.
Old Oct 29, 2005 | 06:40 PM
Chrisconsin
Thank You Very Much, Greystreak & 94 XLT
will take that in to consideration
