Help:
Old Oct 28, 2005 | 10:59 PM
rls302s's Avatar
rls302s
Help:
Hi Everyone
Not really new here just had to change everything due to an opps on my part.
I need to know what to use to plug the air pump ports on my 88 302 after
changing it to carberator from EFI??? stud,plug like a freeze plug??? ect.
I kind of forgot about it when I installed the engine & now I can't see anything to tell whats needed.
Thanks much for any help
rls302s
Old Oct 29, 2005 | 02:05 AM
tude's Avatar
tude
i would just take the junk out pump and all and change the belts over from surpintine to v- belt
becouse surpintine if you just by pass the pump the belt rubbs if i remember and it wont last very long
Old Oct 29, 2005 | 05:43 AM
Neb86's Avatar
Neb86
I'm assuming you mean the ports in the rear of the heads?
If that's what you mean here's a suggestion: Cut the ends off of the old manifold that connected the two ports, weld the holes shut and bolt them on. I don't think those ports have threads in them so plugging them with a bolt or stud would be out and trying to pound a plug in there would be pretty tough.
Hope this helps.
Old Oct 29, 2005 | 08:26 PM
rls302s's Avatar
rls302s
Smile Help: Neb86
Thanks, why didn't I think of that?!,.
Ron
