Sponsored by: Auxito
spare tire winch cable break?
Old Oct 28, 2005 | 10:26 PM
oldsub86's Avatar
oldsub86
I read in a book that the cable that holds the spare tire on is prone to breakage. Anyone suffer the loss of their spare? We have a similar setup on our 4Runner and I have an extra cable on it to keep the wheel locked up so that it is harder to steal. However, I have often thought that if the main cable broke it might be better to have it actually drop off rather than drag as the second cable would not hold it up evenly. Any extra cables make it harder to get the spare out.
Randy
Old Oct 29, 2005 | 02:48 PM
peppermrj's Avatar
peppermrj
Years ago, on my wifes caravan, I went to check the air in the spare. What spare! The steel cable had rusted thru. It would be easy enough just to oil the cable when you check the air in the spare. I'm sue they would last forever that way.
Old Oct 30, 2005 | 07:53 PM
Paul37's Avatar
Paul37
We lost one on our Expy. Lucky for us it was in our driveway, when we came home it was sitting there waiting for us. I can't believe we didn't loose it on the hiway.
Old Oct 31, 2005 | 03:43 PM
lancekilgore's Avatar
lancekilgore
I think that would be rare and pretty easy to check it for rust and then coat it with a rust inhibitor to protect it. that should take care of the problem.
Old Nov 1, 2005 | 08:06 AM
ttom81's Avatar
ttom81
I didn't lose a tire, but mine refused to lower when I had a flat. I kept working with it and finally managed to completely fray the cable into a bunch of broken wires so that it wouldn't go up or down. The tire was hanging in mid air. Luckily it was still under warranty. I don't know if lubricating the cable would help or not. How often does one ever lower that thing?
Old Nov 1, 2005 | 08:25 AM
lancekilgore
lubricating would help and cause you to get it all mucked up with dirt and such a rust inhibitor gets hard and does not collect or attract dirt and protects the cable. Many winche cables come with it on already. but you are right if you keep good tires on then you would rarely use it.
Old Nov 1, 2005 | 08:35 AM
peppermrj's Avatar
peppermrj
Still a good idea to check the air in the spare once a year. While your at it lube the cable. My personal favorite is triflow. Used it on all the cables back in the motorcycle days. Doesn't attrack dirt (teflon) and lubricates. Can be kind of hard to find but real common in bicycle shops around here.
I must of dreamed this but I could of sworn someone replied that the cable is vinyl coated. Maybe the newer one are.
Old Nov 1, 2005 | 09:41 AM
Blurry94's Avatar
Blurry94
I pulled the tire out and threw it in the back...easier/cleaner access.
Old Nov 1, 2005 | 09:59 AM
ttom81's Avatar
ttom81
I guess you're right, Lance. I'll try to remember to put rust inhibitor on it. Thanks.
Old Nov 5, 2005 | 08:00 PM
young-g-ma's Avatar
young-g-ma
cable broke.....spare tire fell driving in town....
glad it wasn't on the interstate...97 f-150
Old Nov 6, 2005 | 09:45 AM
peppermrj's Avatar
peppermrj
Post
At least you found it. When you need the spare and its not there ! LOL
Old Nov 7, 2005 | 09:57 PM
oldsub86's Avatar
oldsub86
My brother in law ran into or over one that fell off with his GMC pickup. Did a fair amount of damage to the truck. Don't want to lose my wheel and don't want to cause an accident for someone else. Dropped my spare and checked things out. Looks alright so won't worry about it for now.
Old Nov 8, 2005 | 07:33 AM
lancekilgore
If the cable locks are installed to keep theives away, when and if the spare falls it should be drug along other than loosing it.
Phy
Jun 29, 2016 11:49 AM
Alfred
Oct 12, 2015 09:22 PM
speakerfritz
Sep 6, 2014 10:53 AM
fbh31118
Jul 16, 2011 02:07 PM
Orezona
17
Jul 9, 2006 12:09 PM
