alternator?
Old Oct 28, 2005 | 07:16 PM
frdrngrlvr's Avatar
frdrngrlvr
alternator?
i listed this topic before in another forum. i've been having problems with squealing from the front-end. i know its in the belt or the pulleys. i just put on a new belt for the third or fourth time and it helped for awhile but it came back after four noise free days. but the squeal totally gave way to a knock like sound. no its not a lifter or a piston or the main-bearing. i listened very closely with a pal of mine and we both decided it was definately coming from the alternator, we could feel it. possibly the noises have been coming from it the whole time and just got worse with the new belt? i'm thinking the bearings are bad. i also have changed the idler-pulley in trying to solve this headache of mine. i've been told to adjust the tension but doesn't the tensioner, set from the factory, do this automatically so as not to have to adjust it?
Old Nov 2, 2005 | 02:54 PM
fordboy_52's Avatar
fordboy_52
yes, there should be a spring in the idler pully to tension the spring. You can replace bearings in and alt, but id run down to orielys and buy a new one
Matt
Old Nov 2, 2005 | 06:52 PM
frdrngrlvr's Avatar
frdrngrlvr
Matt
thanks fordboy. i'm glad about the tensioner because i was kind of baffled about that one. anyhow, i'll be gettin a new alternator this friday and as soon as i put it in i'll let you guys know how its doin. yea and as far as the 3.slow is concerned, man what a pooch. however i do believe we'll get some miles out of 'em.
15
Jan 25, 2017 03:41 PM
Icefan71
1997 - 2003 F150
Jan 15, 2017 07:52 AM
bluemtn95ford
25
Feb 10, 2013 11:30 PM
3speed
Apr 1, 2011 11:44 AM
Paul-FL
Apr 3, 2009 08:00 PM
