exhaust brake
Old Oct 28, 2005 | 07:07 PM
blueeyes2478's Avatar
blueeyes2478
Unhappy exhaust brake help
Im hooking up my ehuast brake that i bought off of ebay,but i have one problem.Im trying to find a 12 volt power sorce,but switched.Can any one tell me what wire to use?It also has to be able to handle 20 amps.I also would like to be able to plug it in right next to the master cylinder,right next to the air box.
Old Oct 28, 2005 | 07:39 PM
Kwikkordead's Avatar
Kwikkordead
Twenty amp load? I would rig up a load reduction relay for that much current. End up cooking whatever circuit you tapped into. It was only designed to a certain amount and to add 20 amps. Well it would work for a while and then you'd be dealing with overheated connectors and brittle wiring.
Old Oct 28, 2005 | 07:43 PM
blueeyes2478
Well thats what the instuctions say,but i dont think that it needs that.All the wires are small,not big enough to handle 20 amps,I really dont think it needs 20.
Old Oct 29, 2005 | 07:24 AM
wildbill1963's Avatar
wildbill1963
The one we offer only needs 7.5A load. Your option is to find that somewhere on the fuse panel. You could also use the customer access wires, typically found on the right side and behind the fuse panel cover.
Old Oct 29, 2005 | 11:32 AM
jason12's Avatar
jason12
has onyone tried one of those electrical exhaust brakes????? if so how well do they work???
Old Oct 29, 2005 | 12:14 PM
Kwikkordead
I converted my EBPV to a brake a long time ago. It works great, but probably not quite as good as some of the purpose built ones. I'm guessing that they provide more back pressure and therefore better braking effort than simply converting the EBPV. However I hardly have to use the service brakes right now when going down the pass if I have the brake on.
Old Oct 29, 2005 | 01:32 PM
blueeyes2478
Post
Thats what i just installed in my truck,works great.
Old Oct 29, 2005 | 02:52 PM
wildbill1963
We offer our version of an Exhaust Brake. It works great.
