Brake Problems
Old Oct 28, 2005 | 04:45 PM
onion's Avatar
onion
Cool Brake Problems
Ok I Have A 97 F250 4x4. The Problems Is That When I Am Driving About 60 The Speedometer Atarts Jumping Around And So Does The Tach. The Abs Light Comes, The Cruis Doesn't Work. And When I Apply The Brakes They Are Ok The First Time I Hit Them But If I Hit Them Again Back To Back The Pedal Is Very Stiff.
The Repairs I Have Made Are As Followed I Have Tried To Had The Codes Pulled No Luck. I Have Replaced The Vaccume Pump And It Doest Not Help I Have Surched The Post And I Have Seen The Rear Abs Sensor A Couple Of Times. Could This Be It I Have Looked At The Sensor And Mine Was Lose So I Tightend It Up But No Change. Please Help It Is Driving Me Crazy The Ford Dealer Ship Just Wants To Continue Replaceing The Vac. Pump.
Thanks
Old Oct 28, 2005 | 04:48 PM
1997F-350's Avatar
1997F-350
maybe a bad vss sensor?????? its located on top of the differential. are all fuses good?
Old Oct 28, 2005 | 07:39 PM
onion's Avatar
onion
Yes All The Fuses Are Ok Is The Vss The Abs Sensor>?
Old Oct 28, 2005 | 09:40 PM
barebackjake's Avatar
barebackjake
the vehical speed sensor
its ontop of the rear diff, its been kinda a known wear out part. sounds like the same symptoms to me too.
