sorry for all the questions im wiring my truck back up, but i was wondering on the cigaratte lighter I know which plug goes to the back but how do you ground the cigartte lighter ? i dont smoke but I want to keep it so I can have a power source to plug into.
also there is a wire running from the wiper motor a single wire that plugs into the accy plug right?
thanks you all have helped alot as I wouldnt have not even gotten this far without your help thankyou.
An outer sleeve screws onto the inner socket.
This outer sleeve has teeth on the mounting edge which shears into any paint to the bare metal on the dash ,for grounding.
Do you not have a cigar lighter to look at ?
Wiper motor.
No, The wiper motor plugs into the main harness.
its a 76 f-250 and the wire i meant its coming from the wipermotor under the dash itself, it plugs into the back of the wiperswitch then it has a single wire with a yellow plug i believe it plugs into the accy plug end if im correct?
