Sponsored by: Kumho
92 brake problem
Old Oct 28, 2005 | 10:04 AM
SNOWDUTT's Avatar
SNOWDUTT
92 brake problem
I have a 92 F250 that I just had the rotors turned and new pads installed. The brake pedal will slowly go to the floor when stopped at a stop light. The brakes stop allright it's just the pedal wants to go to the floor. What gives.
Old Oct 28, 2005 | 10:15 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Oct 28, 2005 | 10:48 AM
texans's Avatar
texans
hello snowdutt, welcome to FTE.
now about your problem. You have what is called a fading brake pedal. check for leaks in the system, if you dont find any then you probably have air in the line. If you had this job done at a shop I would take it back to them, and have them fix it. GL
Old Oct 28, 2005 | 11:42 AM
SNOWDUTT's Avatar
SNOWDUTT
Brakes
Thanks for the info. I had my son helping me bleed the brakes. I think I will have to reschool him. Any chance it could be the master cylinder.
Old Oct 28, 2005 | 11:50 AM
texans's Avatar
texans
yes, I you could have an internal leak in the MC (I could be worng on this thou) that would cause the problem as well. just make sure the brakes are bleed well. if so then you might look into the MC.
Old Oct 28, 2005 | 01:17 PM
andym's Avatar
andym
A slowly sinking pedal is a bad master cylinder 99% of the time.
The reason that it happened after you bled the brakes is that you haven't been regularly changing your brake fluid (not that anyone else does, including myself) and you have some internal corrosion in the master cylinder. The bores are squeaky clean where the seals normally ride during normal use, but the plunger goes MUCH further into the cylinder and tears up the seals on the corroded part of the cylinder bore.
