Suspension and tires
Old Apr 15, 2002 | 02:35 AM
AKFord's Avatar
AKFord
Post Suspension and tires
I have a '79 F150 4x4 with 15" wheels and the stock suspension. I have done the measurements around the tire well and it looks like I can safely use a 31x10.5 tire, definitely a 30x10.5 would work but does anyone have the same truck and has used the 31x10.5's?? Also, was it an option to have dual front shocks? I can't remember seeing it on other 1/2 ton's, anyone know? Thanks!
JD
Old Apr 15, 2002 | 08:09 AM
4fords's Avatar
4fords
I had a 79 with 31 x 10.50 x 15 on it and had no problems at all. I didn't have a lift either, it was stock. I ended up having to get a wider wheel though. I believe you need at least an 8 inch wide wheel to run that size tire.
Old Apr 15, 2002 | 07:32 PM
thitdog's Avatar
thitdog
My 77 4X4 fits 31X10.5 15lts no problem. I have my on a 7 inch wide wheel and they are fine.
Lee
Old Apr 15, 2002 | 08:05 PM
Amule's Avatar
Amule
AKFord,
You can run 33s with stock suspension.Been
there done that.You may run into some slight rubbing
on the radius rods with 8 inch rims and 4 inches
of back spacing.
Old Apr 15, 2002 | 08:10 PM
Amule's Avatar
Amule
AKFord,
Quad shocks were a Bronco option only.
This can be installed on F150s with little
effort.
Old Apr 16, 2002 | 12:17 AM
thitdog's Avatar
thitdog
I've seen plenty of trucks running around with the quad shocks, surely that many people didn't convert them, did they??
Lee
Old Apr 24, 2002 | 03:56 PM
78F150's Avatar
78F150
I've been running Winston Fun and Mud 31"/11.5 /15 with an 8" wheel since 1978 with no problem. Did try a 32" once and chewed up wheel wells in front when off road. But I swear by these Winstons, and they are the only ones I have found who offer a 31" 11.5. Just make sure your front springs are in good condition and don't sag. I did have to replace the front springs after about 20 years.
78F150
Burbank, Ca
Old Apr 26, 2002 | 07:15 PM
gray79f250's Avatar
gray79f250
you could put 33s on it if the springs arent shot from plowing etc even the 31s look great if you can get ahold of some 10 inch wheels
ANDY
Old Apr 26, 2002 | 08:36 PM
Jermafenser's Avatar
Jermafenser
Quad shocks were offered FACTORY in F100 and F150. That option is only available on 1/2 ton pickups. It is not a Bronco-only option.
Old Apr 26, 2002 | 10:49 PM
Fatrap's Avatar
Fatrap
I run 31/10.5/15 on 7 inch factory wheels on my 78 Bronco... which is the same as your pickup down there. I replaced the front springs with HD springs years ago, which forced me to lift the rear about 2". I have no problems at all.
Old Apr 26, 2002 | 11:42 PM
spygot's Avatar
spygot
