Sponsored by: Real Truck
2005 headlights
Old Oct 28, 2005 | 06:48 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
2005 headlights
I have contacted PIAA about their 9008 release date for that bulb....no answer at all (great customer relations) ...has anyone heard a good rumor about a bright headlight for the 05 SD.
Old Oct 28, 2005 | 08:23 AM
dmp437's Avatar
dmp437
Have you upgraded the headlight harness yet?
Old Oct 28, 2005 | 08:49 AM
Matt M, PA's Avatar
Matt M, PA
Tim...I went through this last Winter with my '05 Excursion.
The new lamps, 9008 or H13 (same thing, different name) are a newer bulb. They supposedly offer better light output. The problem is...DOT when certifying these lamps...wrote that they cannot be a coated bulb. Silverstars, PIAA white bulbs, etc, are coated with a color tint. So, unless PIAA comes up with a "regular" 9008, there won;t be much in the way of the aftermarket here in the USA. I guess there could be somethhing overseas you could import, but I did not find anything for mine.
All is not lost, however. Sylvania makes an upgrade to the 9008 as an Xtravision bulb. I mail ordered mine. My understanding was that they are as bright as a Silverstar, but the "standard" color of light. If memory serves me, 20% or something like that. (Probably worded "up to 20%) I installed these and they are a bit of an improvement.
The biggest lighting improvement I saw was to switch the fogs to 9005s. They plugged right in and made a dramatic difference. The slight increase in power usage does not seem to be an issue.
Old Nov 4, 2005 | 07:42 PM
labwillow's Avatar
labwillow
Hey Matt, I have been looking for bulbs for my '05 where did you mail order these from?
Old Nov 4, 2005 | 10:57 PM
Matt M, PA's Avatar
Matt M, PA
labwillow...sorry to say, I can't remember. I do know that after I spoke to customer service, I had a couple dealers to try. You may want to call Sylvania customer service. I found their number on their website.
Old Nov 11, 2005 | 11:21 AM
Quepas00's Avatar
Quepas00
Is this it?
The address did'nt work. Just go to their site and type in automotive ligthing.
Old Nov 11, 2005 | 05:41 PM
MattamiscontisME's Avatar
MattamiscontisME
Matt,
You said that you put the 9005 bulbs in your fog lamps. You didn't upgrade the wiring or fuse or anything like that, right? Have you had any problems with overheating or burning? Do the lenses get hot? How is it in the summertime?
Also, would you recommend the Xtravision bulbs? Are they worth spending the money on? I saw on the Sylvania website that the lifespan of the Xtravision isn't that of the stock bulbs, but much better than the Silverstars. Have you had any issues with that?
Old Nov 11, 2005 | 07:58 PM
Customz's Avatar
Customz
Do you guys know if the XL trucks (sunken headlights) changed the bulbs as well?
Old Nov 11, 2005 | 11:35 PM
Matt M, PA's Avatar
Matt M, PA
MattamisscontisME...first, the 9005s. I have had them in for almost a year, with no ill effects noticed. I also installed them in my '03 Cobra. (The bulbs needed a slight trim on a tab, but on the Ex they went right in.) I installed them on a summer day, and left the lights on for quite a while. I checked with an infrared thermometer at the lenses, connectors and wiring. I noticed no difference except a slight increase on the lense. Not a huge difference.
To figure the amount of power required by them, you divide the watts by the volts. A 9005 would use 5A, a 9145, 3.75. Even when doubled as there are two bulbs on the car, you are still only seeing a difference in used power of 2.5A. I talked to a lighting designer friend who thought it unlikely for this power increase to cause trouble.
A Rep at Sylvania said that the Xtravisions were the same brightness as a Silverstar, but the same color as a regular halogen. It all has to do with the placement of the filament on the bulb. I did not notice a big improvement with the Xtravisions. The best bang for your buck is a set of generic 9005s for the fogs.
