timing ?
Old Oct 27, 2005 | 09:30 PM
oldsw-31's Avatar
oldsw-31
timing ?
I just borrowed a snap on timing light mt2261 from my friend and I was doing the timing on my 89 ford f250 351W . Now on the balancer there is the degrees stamped in it. unlike on the timing tab , ok so I marked the balancer on the 10 degree ( stock base timing) mark removed the spout connector. and fired her up my ? is what is the purpose of the timing advance buttons on this gun? Because what I did was set the light to 10 also which I thought would give me a total of 20 base timing correct? this is what my friend said when he gave it to me to do? . Now should I have had marked the Zero mark on the balancer and the used the advanced button set to 10 and set it there? or just left the gun set to zero and used the 10 on the balancer?
Old Oct 27, 2005 | 09:42 PM
Popa Tim's Avatar
Popa Tim
Since you marked the balancer already, I would set the gun to 0 and use the 10 degree mark on the balance. I suppose you could use the 10 mark on the gun and 0 on the balancer as an accuracy check. Either way works though, I just don't trust the gun to adjust correctly.
Old Oct 28, 2005 | 07:42 AM
oldsw-31's Avatar
oldsw-31
according to snap on the gun has a accuracy of 1 degree. For a tool that cost over $500 So I think I set the initial to 20 since i used both the 10 mark and 10 on the gun
