Gt F150
Old Oct 27, 2005 | 11:09 AM
LANEGRA99's Avatar
LANEGRA99
Gt F150
I am doing a conversion on my brothers truck, a 1995 6 cyl F150, going with a GT 1986 Mustang engine which will be carburated, what am i going to do about the fuel delivery system? i have the high pressure fuel pumps on the tanks, and i know that is to high for the carb.
If i hook up an inline pump, will it suck thru the in tank pump? or do i have to replace the pumps in the tank? NAPA says it would be easier to add an inline pump for each tank and keep the tank selector as a swith for either pump.
how can i configure this set up where i still have tank selector, fuel gauge display and get the low fuel pressure for the carburetor.
Thanks for the input anyone?
Old Oct 27, 2005 | 10:36 PM
Joe fix it's Avatar
Joe fix it
I believe you can buy a fuel regulator that takes the 50 or so psi and turns it down to a more carb friendly psi. I think I seen it in a jegs or summit catalog
Old Oct 28, 2005 | 08:32 AM
frederic's Avatar
frederic
You can regulate it down, however by removing the EFI computer there is nothing left to tell the fuel pump to turn on. You'll have to rig up a switch.
You'll not get much pressure trying to draw through the existing EFI fuel pumps.
The pump is at the end of the tubing that hangs off the fuel float/pump assembly. Remove the pump, and make an adapter that reaches into the tank where the pump used to reach.
predaina
29
Mar 29, 2011 07:07 PM
flatlander757
Mar 30, 2010 07:10 PM
railbuggy007
Dec 18, 2009 09:50 PM
js2743
Oct 9, 2007 06:47 PM
js2743
Oct 9, 2007 10:53 AM
